Panos
Hi all, first post in the forum, I need some help/guidance on a clutch/gearbox issue I am having with my GS (K50 LC 2013 model).
My driveshaft broke one morning on my way to work (the front cross broke…) but unfortunately took the gearbox output shaft out as well..
I dropped the engine, removed clutch and gearbox, and installed new clutch discs (aftermarket Recluse one) and a second-hand gearbox I got from eBay. I also flashed the hydraulic fluid on the clutch, and I can confirm that when the clutch lever is pulled in, I can see movement in the clutch basket, the discs are pulling apart. Of course, I also had to replace the driveshaft
Now, I got two problems:
1. I got no 2nd gear or upwards. Just first and neutral! Bike starts, goes into 1st gear, I release the clutch the wheel spins. I am trying to go into second and it’s like I am hitting a wall, foot pedal doesn’t move. Just to note that I tried the used gearbox before fitting into the bike and it cycled through all gears as expected.
2. Clutch is very stiff when in first gear and lever is pulled all the way in, it’s almost impossible to move the bike, it feels like the clutch is still engaged or something.
Any suggestions / ideas would be very much appreciated, thanks all!
