macmanCZ
Hi, my English is not perfect, so I prefer to use an automatic translator.
I have a 2012 R1200GS motorcycle with DOHC engine... The bike rides well, but has a higher consumption when riding quietly... I found out by diagnostics that the bike reports a fault in the O2 sensor on the right side...
I swapped the two sensors between them and the fault is the same... On the graphs I could see how the second cylinder cycles between rich mixture and lean, while the first cylinder cycles irregularly... After warming up it eventually stops cycling altogether and shows the same voltage.
After synchronizing the cylinders, it no longer cycles at all, only randomly appears to change...
I found a wiring diagram on this site and checked the cables from the ECM to the probe. It's fine.
I swapped both injectors, the 1st cylinder still doesn't cycle, the second has strange readings..
I really don't know how to proceed... I understand the engines, the electrics too, I have the diagnostics.. but I'm still stumped..
Before injectors swap, cold engine, idle RPM: https://photos.app.goo.gl/ofuhPZH398z1hKUA8
Warm, idle RPM: https://photos.app.goo.gl/Ussow5mvhXrriVpC8
Final values after injectors swap with increased rpm: https://photos.app.goo.gl/DSBwst5Exv3cSQ3B7
Idle rpm: https://photos.app.goo.gl/BV1GDFbFj1DvZGEh6
Macman
Macman
