asprint
Hi
I have a 2003 ABS R1150GS on which I want to change the brake fluids but I having a problem doing so and would appreciate some help/advice.
This is the first bike I have owned with an ABS system, yet it is/was my understanding that unless you wanted to change the brake fluid within the ABS module that you could ignore it and just change/bleed the brake fluids as you would with any non ABS bike?
To that effect I removed the master cylinder cover, fitted a drain tube to the left/nearside caliper nipple and proceeded to try and pump the brake fluid from the caliper/brake line. This proved very difficult and whilst brake fluid was being removed very little was being drained form the master cylinder?
I then connected the drain tube to the right/offside caliper nipple but in this case mostly only air came out, but still the master cylinder remained more or less full?
What seems to have happened is that the brake fluids have be drained out of both the front brake lines and calipers but nothing is draining down from the master cylinder, consequently I now have no functioning front brakes as I cannot get any fluid from the master cylinder into the front brake lines.
Clearly something is amiss and I suspect that this is a procedure error in the way I have assumed you can change the brake fluids and that you cannot simply ignore the ABS module?
Have tried to find an online video of how it should be done but cannot find one that covers the ABS module fitted to my bike only those with the separate reservoirs and the 6 separate nipples you also have to bleed?
So can somebody advise where I am going wrong and what is the correct procedure to change the brake fluids? Is the some clear written documentation that covers how to do it or an appropriate video?
