NormGS
Hi all, pleased to have joined this forum.
I have a 2005 BMW R1200GS which was on trickle charge over winter. One month ago I started it up and it ran perfectly but I have just tried to use it and it won’t start and there is no whine from the fuel pump when the ignition is switched on.
After doing some reading, I suspected it was the “fuel pump controller” which I also think is called the “driver module”? I purchased a new one and swapped it over but still there is no whine from the fuel pump and no start.
I then took the bike for diagnostics at an independent dealer who used the GS-911 to read for faults. It came up with “Fuse activated for electric fuel pump” after clearing the code the bike was tried again but the fault just came back. The technician tried a different fuel pump controller but the fault came back again.
Is a new ECU the next step?
Norm
Norm
