Bike has been sat in garage over the winter period & kept on a battery optimiser. Ran it during this period to make sure things were ok (all good), however today I took it for its mot and the yellow warning triangle started to flash. It the turned to red & continued to flash. At the test station I turned the bike off when I came to start I thought it wasn't going to start (had symptoms of a low charged battery) eventually it fired up. I warned the tester as I did not want it to be a problem on test giving him the opportunity not to test if he wished. Left it running for a while red warning light still flashing. The bike did however start without fault after that, during the test the red flashing triangle stopped altogether. On the way home its come back on
Has anyone had this issue & if so can you point me in the right direction for what I should be looking for
Many Thanks
Many Thanks
