Dr LC8, the forks are WP48mm open cartridge off a 2008 690 enduro, with .69kgf springs fitted to deal with the extra weight (me and the bike). The stroke on these forks is only 250mm unlike the EXC fork which is 300mm so it doesn’t sit like a chopper with the front raised too much. The fork caps are flush with the top of the yoke.
I can’t answer the question about geometry because on this bike I‘ve also fitted an 18” rear and a taller tyre so the back is higher than standard. There is also a heavier spring on the rear shock which means it doesn’t sag anything like as much as the standard bike. It is significantly taller than my standard R80GS basic, which is fine for me because I’m 6’5”.
I don’t know about the front brake yet because I haven’t connected the master cylinder to the calliper. That’s the next job on the list. The master is a new BMW 13mm unit and the caliper is a new KTM 690 one. I’ll let you know once it’s plumbed up and got fluid in it……
