Kiwi
I learned the hard way. I have just rebuilt a crashed R1200GS. All on the road and going well. Then last week the clutch started playing up. When releasing the lever the takeup was very slow. My repair included a new clutch line. I pulled the slave cylinder off (Two screws) and found it had seized solid.The seal was rooted. (Bad)
So I finally read the BMW manual (CD) which lists Vitamol v10 as the correct fluid. This is a mineral oil, NOT brake fluid.
Well I should have known. It is clearly written on the clutch reservoir cover, in bright black on a black background.
Down to the local seal importer and purchased the slave cylinder seal, two master cylinder seals and an o-ring for the reservoir. NZ$24 all up. (US$18)
The very nice man at Seal Imports Limited (which I had previously assumed was some sort of supplier to zoos) said, "Make sure you don't use these with brake fluid as they will swell and disintegrate." "Yes, well I know that now..."
So be warned. Use the correct fluid.
Even the parts man at my local BMW dealer at first made the same assumption. They have never had to work on R1200 Clutch hydraulics in the three years or so that they have been on the market.
All good fun!
All good fun!
Not my fault(previous owner)not theirs either.Parts going to take a week to come.Oh and the bill is going to be bigger.
