bumpmuncher
hello i have a valeo and the magnets have fallen off
and wont let it work anymore
can anyone tell me what other starters fit and also what cars i can get them off (cash short so will see if i can get one from a local breakers) one of the magnets has broken in two would it be worth drilling and taping or will i have trouble with the broken magnet. my car is not working at the mo either (building new engine) so i could do with a reasonably quick and inexpensive repair. if anyone has any suggestions
thanks. mark
you need a rapid cure epoxy) then i drilled the starter casing with enough holes so each section of magnet could be screwewd into place. after gluing the magnets back into the casing i found my second problem, driling magnets!
then i found the first problem one of the glued magnets was nolonger the right shape and jammed the armature so after afew
and decided to go to the scrappy after work. I wandered around for half an hour and found a suitable donor in a 1.2 corsa. they can also be found in peugots, citroens and a few others. there are a few diferent d6ra valeo starters the motor and solenoid are interchangeable with the airhead starter so any of them will do. then all you have to do is swap the motor bit over. in all it cost £20, £5 for the glue
