AxeGrinder
Hi...I seem to be visiting this page a lot this weekend!
OK, whilst dabbling with speedo/idle issues, I came across this
It appears to be emulsified oil, that has dripped from the crank case breather pipe, onto the BMS and a couple of other bits.
At first I was horrified
but after checking fluids, all seems to be in order, no coolant in oil, no oil in coolant
Just wondering where/how it may have developed...I've not seen this happen on any bike or car I've messed with before
Also...the elaborate termination of the pipe, would upon examination make me think it should connect to something...or is this just BMW's way of adding parts that are not really required?
Any ideas?
Any ideas?
it looks like its just pulled itself out somehow, push it back in throught the rubber bung and it should be good to go.
I'll be going to work on it tomorrow anywat, as I'm getting tired of removing 1000000 screws just to get at the airbox!
I've started leaving out the odd screw here and there.
from a not so dispondent AxeGrinder
