Just thought Id share a couple of email conversations I had with Opie oils, this was prompted by a request for their recomendation for a 1200GSA. I then discussed with them the data sheet on Mottorads site with BMW speak!!
I bust my chops to be able to afford this bike and am pee'ed off with this constant attempt to milk me further
Sent: Thu 05/08/2010 15:44
To: Opie Oils
Subject: Opie Oils - Recommend an Oil
The following enquiry was made from the Opie Oils Contact Form:
Telephone: 01526345788
Email: [email protected]
CAR / BIKE DETAILS
Customer checked WOPR?: NO
Make: BMW
Model: R1200GS
Year: 2009
Engine Type: Petrol
Engine Model:
Modifications:
Driving Style:
Additional Information:
Sent: 05 August 2010 15:26
To: Ian Ransom
Subject: RE: Opie Oils - Recommend an Oil
Hi Ian
You need a 15w-50 oil and our selection is below
http://www.opieoils.co.uk/c-784-15w-50.aspx
The Silkolene Pro 4 and Motul 300V are two of the best oils on the market, but as a good value day to day oil, the Motul 5100 is a good choice.
Regards
Tim
OPIE OILS
Sent: Thu 05/08/2010 16:17
To: Opie Oils
Hi
SOrry to be an anorak but I found the attached file on BMW web site if your users are to keep within the bounds of warranty then Im afraid
your recomendations are incorrect.
Regards
Ian
Sent: 05 August 2010 16:38
To: Ransom, Ian P.
Ian,
Just had a look at that PDF, your bike comes under the boxer recommendation? Castrol/BMW's top choice is for the Castrol Power 1 Racing 10w-50 fully synthetic, this is actually an old oil that Castrol discontinued a few years ago, when BMW introduced the new R1200GS Castrol re released this oil as the preffered choice and is currently only available through BMW dealers (racketeering at its best!) What is interesting is they also recommend the Castrol ACT Evo 20w-50, and this could not be further apart quality wise from the 10w-50 as it is a basic mineral mulitgrade oil. So it spells out to me that the usual scaremongering tactics are in play often seen with BMW and Castrol.
It is against the law to only recommend one specific oil and that it can only be purchased from one place hense the suggestion of the use of the 20w-50 that is readily available. However both BMW and Castrol will scare owners as much as possible that their warranty will be invalid if the 10w-50 is not used. All other reputable bike oil manufacturers are recommending 10w-50, 15w-50 and also 20w-50 for use in the R1200GS.
I would be interested to see what you handbook has to say on this, among the viscosity 10w-50, 15w-50 etc you should see and API specification for the oil that should read something like API SF/SG, are you able to confirm?
Regards
Guy.
Sent: Thu 05/08/2010 20:09
To: Opie Oils
Hi
I was out on iphone for my 1st reply. The handbook says API, SF or better or ACEA Class A" or better, according to Wollaston this will be updated!!!
My rsponse was that if it was that critical surely they should hand out a supplement to the handbook at time of sale!!!
Its all crap designed to scare!I will of course be using the cheaper option!
DOnt suppose you can supply the gearbox and final drive oils?
Regards
Ian
Ian,
Thanks for the confirmation on the handbook specs, as I suspected an API SF or better (using oils that meet these specs or above is what gives the customer freedom to use different oils, and ammo should there be a claim), the ACEA A stands for petrol, usually there will be a number after it so it will read like ACEA A3. As a point of interest ACEA B# stands for diesel.
For the gearbox and final drive you can use the same oil, the officialy BMW oil of choice is the Castrol SAF-XO here http://www.opieoils.co.uk/p-737-castrol-saf-xo-75w-90-synthetic-final-drive-lubricant.aspx It is a very good oil, so I would go with it.
Regards
Guy.
OPIE OILS
To: Opie Oils
CAR / BIKE DETAILS
Make: BMW
Model: R1200GS
Year: 2009
Engine Type: Petrol
Engine Model:
Modifications:
Driving Style:
To: Ian Ransom
Hi Ian
Regards
Tim
OPIE OILS
To: Opie Oils
Hi
Regards
Ian
To: Ransom, Ian P.
Ian,
Regards
Guy.
To: Opie Oils
Hi
Regards
Ian
Ian,
Regards
Guy.
OPIE OILS
Oil you can only get from BMW dealerships. Is this a high reving sophisticated engine........I don't think so. They are taking the piss with this oil recommendation and the dealships will just go along with it and we pay the price for their 'sweetened deals'.
