DIY R1100/1150GS rear rack reinforcement
essjay
Drogheda, Ireland
Had a couple of hours today and thought I'd take a crack at beefing up the rear rack.
Buy a couple of bookshelf brackets in a local DIY shop (€6)
Mark out where it's to be cut.
Cut to size with a hacksaw
Bend into shape
Shorten bracket to size
Cut a small piece from the end of the bracket
Drill hole & bolt to frame. I still need to bolt the bracket to the luggage rack
Before bolting it to the luggage rack I'm going to run some 20mm x 2mm steel bar along the inside the frame to beef it up a little more. Like the photo below.
just one point
the fd fails cause nut like you stick reinforcement on a bike that you already overload
welcome too the club that is ukger :comfort
this is sam on my bike :blast
as you can tell he rides a gs :D
I always overloaded the rack on my 1100 GS, I even drilled holes in it just where they crack to add another rack onto it and it has yet to crack! (I kept the rack when I sold the bike). Kitchen sink tours rule!!!
Yeah - reckon they are strong enough unless you go off roading with a full top box. That said, I decided I'd beef it up anyway. Prevention better then cure and all that!
