Right Angle Hella/BMW style Plugs
Popeye
weaving thru' the GATSO's
These aren't that easy to come by in the UK.
Screw terminals, as oppossed to soldered and made in Germany, not a cheap Chinese import.
I've got a bulk quantity to work my way through. Some will be for my PowerPorts, some will go on ebay and some are on offer here at a reduced cost.
Priced on the basis that payment is via PayPal as a gift, £7:25 each + £1:00 to cover the cost of postage (75p) and packaging (25p).
Two please if you have them. PM to confirm and I'll make the payment.
Thanks Allan. Got the plugs (male and female) yesterday and installed them. Much easier to have the port on the beak rather than faffing around with the battery and the Canbus. Found a good place in the beak (but for those that follow there is a steel frame underneath so make sure you don't hit it). Can't understand with this isn't standard. The stock plug is really in a stupid place and you can't even put a pump on it. Wired the two plugs to my pump and charger and works a treat.
Yep, with you there. The under seat socket is just in the wrong place. Used to have to tape the satnav cable to the tank. The can-bus often refused to allow power to the Zumo, then the wires corroded and I eventualy removed the hole thing. :rolleyes:
I've put two sockets on the beak. Both wired direct from the battery with in line fuses. I can now run the sat nav and have another lead in the tank bag charging phone and batteries etc.
I managed to find some of these 90o plugs (after a lot of searching too) about three years ago and they make things much tidier. Well worth the money IMO :thumb2
Val.
