ADV to standard GS seat swap
Den
Scotland
For anyone considering this, Ive swapped them back and forward 4 times now due to Mrs Dens comfort expectations.
Do-able in about half an hour.
Remove adv seat
Remove front seat bracket and spacers under bracket 6x screws. Pic1 / 1a
Unscrew, but not fully, black plastic screws which connect the coloured and black plastic parts of rear mudguard. Pic2 Pull screws and they will come out with the screw socket thingys which go through the mudguard halves.
Remove rearmost screws from rack.
Mudguard will now dangle down.
Look underneath rear bracket with seat lock on it. Pic3 4 screws hold this on from underneath, remove these.
Remove remaining 4 screws holding rack.
Remove rack.
Remove screw holding combined helmet/seat lock to frame.
Remove lock/ cable and rear seat bracket as one unit.
Pic1
1a
pic2
rear bracket screws Pic3
Fit R/H front seat bracket to frame ( the one that looks like a bit of mecanno) 2 bolts. Pic A . Fit R/H front seat hook thing to bracket With slots pointing back.
Do same to L/H side. This might come with Mecanno bracket, seat lock and seat hooks as one unit if secondhand.
1 screw holds rear of this assembly to frame.
Fit R/h pillion seat hook to frame 2screws.
Rejoin mudguard halves and push in connectors. dont screw the plastic scews back in, just push them home.
Fit new rack. Bolts at back go right through mudguard to light bracket.
Slip in tooltray. Secure with 1 screw at back.
BEFORE FITTING SEATS.... you will have to re key your seat lock. or you wont get them off again. Locks come out easy enough, just swap them over.
I think thats about it, oh before I forget . Dont fit red seats.
Pic A
Is it really that easy.
I've just upgraded to a Adv. from a 1100gs and my old seat was a corbin, having covered over 70,000 miles on the thing, I would now consider it to be fully broken in! Thank god I don't have to buy a new one.
thanks,
Paul:beer:
Hi Den
Good description, but I'm more interested in the black rack you have fitted. Looks alot more usefull than the standard one, whats the info on it? Is it a top box mount?
its the standard bmw top box mounting plate. Not for sale. Still have to swap seats when on holidays with wife
Are you still able to fit the seat to the GSA, even if you have the Alum system luggage panniers etc.
Where did you procure the tool tray from to finalise the seat swap!
Do you really need this part.
Tool tray....
standard on the GS
PS: Ally Adv Panniers will fit both GSA and GS
You need all of this..........
Will you need to carry out the same exercise for changing the front seat only!
Very rarely use the pillion seat.
Yes...........what you going to mount the front seat onto...........fresh air??????????????????
As I don't use the pillion seat much at all, do you still need to purchase the tool tray!
Paul
Dont bother with the tool tray. You can get much more in that space by using a couple of tool rolls or bags. And it rattles less
