It's thrown a Con-Rod...!
Coolcarbon
Elsewhere....
Zummerzet,
Had the thing a few years now but probably only used it a couple of dozen times...
A few days ago I was pumping normal 'Scottish Mix' air (None of this Full Nitrogen stuff) into the Bullet tyres when all of a sudden the pitch of the motor changed somewhat, joined by a worrying rattle...:eek
Result...
Anyone else suffered such a catastrophic failure whilst pumping...? :D
There's probably a "Dr Airman" on the interweb somewhere bemoaning the poor design and materials.
Just imagine how catastrophic that could have been if it hadn't happened at home. You might have had to use a foot pump! :eek:
same here - but with a cheaper one.
Frustrated at not being able to bodge it somehow! :D
Hopefully the failure is a one off but
Should you decide to replace like for like £12.39 on Amazon.
Including free delivery
I know because I bought one last week. :eek
Fashion a splint using lolly sticks and cow gum recon that will work :comfort
Surely not! :confused: - the sheer awesome power of the beast cannot be contained by such feeble means! :eek:
but i'm hatching a plot using wire wool, epoxy and 'chemical metal'. :pullface
:D
You should leave it inflated after use - instead of pumping it up, and pumping it.......................... :augie
Yes, I've had it happen on a different pump with identical internals.
I'm waiting delivery on an identical one to yours. I might disassemble and lubricate before each use.
Basically they're crap.
Then I suppose there is the BestRest pump for £85.....
John
Where's the "Not Fit For Purpose" brigade?
You're lucky it didn't happen in the fast lane of the motorway, it could of had you off...
Result...
Liquid metal or Superglue should do it.:eek:
Strip the beast down and send me the rod to weld up and I'll send it back free of charge(unless I completely feck it up, then it goes in the scrap bin)
The offer is there if you feel up to a bit of heavy engineering:beerjug:
Won't welding it set my lolly sticks on fire? :blast
Just spent ages dismantling it (well two screws actually)...:augie, so after all that effort, I will indeed be sticking the offending bits in a Jiffy Bag tomorrow..
Do your magic Sir, and I thank you for the offer...:thumb
