CaJa Sahel : Tourenkoffer :
This is the mount bracket. You can see where the exhaust extension fits onto the Mount frame.
This mount bracket is one piece for shere ease of fitment.
This is the standard exhaust extension.
With your set of CaJa Sahel you get an exhaust extension
either standard or Remus.
Some detail .
CaJa Sahel are the culmination of years of using other makers
panniers. With every set of panniers there is particular strengths
and weakness,s . I believe i am offering the optimum set of
panniers. What you see here is a 43 ltr. set .
You can formulate your own set of panniers for what you intend
doing , should you require extra fuel , water , food storage.
Or simply more capacity.
The cost of a standard set is £500 . The cost of the Top box is £150 .
civil my old flower.
any chance of some photos to show how the top box and lids seal?
and a look at the new smooth weld version
what way do they mount to the rear carrier?
where can i get a look at what you can fit for locks and costs?
does the top box lid hinge?
or does it lift off, if it lifts off do you offer a hinge version? how much extra for that then.
do you offer any sort of finishes yet?
Smoothie baby !
I think you can see the smooth finish on the above photos
The system is designed for simplicity.
The Actual Top box is bolted to a Rear extended rack.
This rack in turn is bolted to the rear of the Subframe , using
longer allen key type fasteners which use the existing mounting
for the rear carrrier, albeit longer bolts.
You have the Choice of the Dzus or Protex catalogues.
The costs of extras are determined by the ACTUAL cost of
putting what you want into the Panniers. You could choose a
toggle latch that would require cutting and welding , which could
be expensive. With all extras i am here to talk and figure out
the best way to achieve what you want.
You can any combination you want .
I Can offer you a custom Pannier set. You can have a set of panniers designed and built for what you intend to do.
Hinged or otherwise
Powder coating . In any colour you want !
I think i can even get you a set with Daisys On em !
This option costs extra.
Thanks Tuned in !
I thought this was brillant !
This is the Home page on my web site.
well civil you can give me a price on this then.
17" wide
14" deep
11" high
i want it hinged and i want a lockable butterfly catch on it.
i also want to know the cost of gettin it with a finish matt or satin black.
can you give me the price options for powder coating and anodising.
it's to have those angles on all sides
matt or satin BLACK
the pic i made up is you looking from behind the bike at it . if you know what i'm on about.
it's only a guide to what I want for you to give me a price on it i'll give a more accurate description when or if I go for the top box (depends what the total cost will be)
Cut out !
This particular Cut out was made slightly larger than normal.
Which i dont think is a bad idea.
Keeping the Whole thing a wee bit cooler.
All helpfull suggestions welcome.
