RAM-man
depleted member !
I am thankful to 'Darkhorse' who called in to get some bits to fit his 12GSA and I had a chance to look over it. So to 'Shenzi' and others who have asked, here's my thoughts.
Darkhorse says he will post some pics later onto the thread.
Tubular handlebar rails
The U-bolts mounts are Ok, so typical mount kit parts; RAM-B-149, 149Z and 149ZA or a camera mount RAM-B-149Z-C1 will attach.
Oval rail
The oval rail up and over the clocks (same as the 12GS) use same U-bolt mounts RAM-B-149, 149Z and 149ZA plus the shim adaptor, RAP-319. Arm length (standard or short) is a personal choice but I liked the RAM-B-149ZA with short arm plus cradle, even for a 2610, but what's in an inch anyway
Windscreen rail bar
Again use a RAM U-bolt mount and RAP-319 shim adaptor. Depending upon the gps unit, my thoughts are RAM-B-149ZA (short arm) for 2610 and RAM-B-149Z with 3" standard arm for say a Quest ?. The Windscreen rail is thinner, but with the RAP-319 shim added it still allows the nyloc nuts to be tightened.
For added padding, a rubber wrap around may be useful.
RAM-man
Oval rail
. Windscreen rail bar
RAM-man
