Just checked the invoice - UKP 25.96 for the "Fixture" and UKP 49.26 for the "Sx Cable Nav" which I assume is the connection cable to the wiring loom. The "Nav 3" was UKP 846.81. (all prices less VAT).
Did you require a special power lead or was the standard BMW lead ling enough. I would like to move mine from the handlbar cross bar to the screen mount as yours is.
Don't know is quick answer! I ordered the power lead with the rest of the Nav 3 system and was dealer fitted. Not much help so maybe best to contact a dealer. I'm not in UK at the moment so unable to check the bike which is there!
Yes that's it. When you fit the clamp initially, a little bolt and locknut are adjusted in conjuction with the quick release lever to give the necessary range of movement to loosen the clamp and allow it to rotate. I hope this makes sense - it's a pretty solid and simple mounting by the way.
