I don't believe you.
Experience tells me otherwise.
See below, keeping a battery fully charged will protect against cold. I need to put mine onto charge as it is now parked outdoors under cover not in a garage within the house since I moved
Car won't start in the cold? Causes and solutions | RAC Drive | RAC Drive
When the temperature drops, you may experience problems with starting your car. Here are the possible causes and solutions for a car that won't start.
www.rac.co.uk
"Can extreme cold kill a car battery? A fully charged battery will freeze around -57°C, a fully discharged battery will freeze at around 0°C. Your battery probably won't work after thawing out, if it does it will be weaker and won't last as long. It's best to replace a battery that's been frozen"
