Hi All
I have a 2013 GSA Twincam and I am in the process of trying to remove the front ESA unit. I have disconnected the 2 cables from under the tank. Removed top nut, washer, rubber bung and the metal sleeve. Jacked the front of the bike up and removed the bottom bolt and released the anti twist plate but I am unable to get the shock out. I have changed the ESA settings to SOFT and no helmets but this has not made and difference.
Would a set of coil spring compressors help or is there another way?
Dave
Dave
