shaunclark
Hi All,
As the title suggests I'm struggling big time with the bleeding up of the rear brakes on my 1100.
I've read various forum posts on brake bleeding on this and other forums and I've tried traditional pedal bleeding and also syringe backwards bleeding from the brake to the ABS nipple then from the ABS to the reserviour. I even tried unscrewing the bipe from the top of the master cylinder and bleeding that line up then refitting it!
It's worth me letting you know that if I disconnect the pipe at the top of the master cylinder/brake pedal then then put my finger over the hole and pump a few times then it does build pressure so I'm convinced the master cylinder is not faulty.
when I connect everything back I simply can not get any pressure at the peddle - it drops as low as possible to the floor and has nothing there!
All Help/advice is welcome... I'm willing to try anything as I need to get the bike in for re-test ASAP as it had failed MOT on the pipe which I replaced.
Thanks!
Shaun
Thanks!
Shaun
