On my Hex EzCan 2, I'm using both the "light" options, one for controlling a set of spots, the other for controlling my Wunderlich Heated Seat (2019 R1250GS). I have a 3rd set of spots I'd like to add, which I am quite happy to come on/off with the ignition (I'd probably add a small on/off switch under the seat in case I don't want them on for any reason). Personally I can't see why I can't utilise the accessory option/tail for achieving this, given I have no light options available. The only other option is to add the additional spots to the circuit I use for my current spots, but I'd sooner not do that, as there will be times when I just don't want a set of spots on (I maybe should add that these spots are 10amp and wide angle, so more a DRL/running light than a spot)
Unless anyone can advise otherwise?
