Mr K
From another forum in the last 2 days......
I needed a pair of levers to tide me over until my pazzo's arrive next month. I went on to ebay and saw the below ones... I know they were "too cheap" but thought if its only quality a month with them should not be a problem... how wrong...
The fitment at first seemed fine and after fitting both levers I took it for some slow speed tests after bleeding and doing a general brake check, it all checked out fine. What I had failed to notice was the brake lever was very slightly pressing on the actuator and without the need for any adjustment (there is no grub screw in the back of the lever to allow free play) and the fact the brakes were free when not applied and gripping well when applied I decided to take it for a shakedown last night... this proved to almost be fatal... after about half a mile the brakes suddenly came on full lock on a roundabout almost causing me to lose control. as it was they were locked on so tight I had to get a driver to help me manhandle the bike to the side of the road and wait 30 mins for the fluid to cool and the expansion this caused to free off the brakes. It was then a very slow back brake only ride back to swap back to the old and worn carbon levers. I have had to take teh brakes apart to ensure nothing is damaged and completely flush the old cooked fluid out and replace the levers.
You'd know straight away on mine because you'd hear the servo running.
