Here's a strange one.
The bike's a late-ish 1100.
At about 5000 revs, oil starts to seep out around the front of the oil filler cap on the rocker cover. Not loads of oil, but enough to start to drip off the back of the cover after 20 minutes or so.
It's not over-filled (the bike has just started doing this and I have not had to top up the oil for ages).
It's not a dodgy cap (I had a rubbishy locking one when I noticed the seeping, so I switched back to the standard one and it continued).
As far as I can see there may be two problems.
A blocked crankcase breather? I had a bit of a look, and could not see any sign of a breather, is it directly below the airbox?
A dislodged seal within the rocker cover? The cap actually locates into a black plastic insert in the cover, and there's a bit of movement between the insert and the cover (pic below). I can easily believe that the movement would be enough to allow a seep. Should the insert be fixed absolutely solidly? If so, how do I go about firming it up? (If this is the problem, I'll squarely blame that Wunderlich locking cap for dislodging the seat because of the amount of fiddling it takes to get it to locate....)
The way it fits, though, it seems that twisting the cap into place might be intended to 'snug up' the plastic seat between the cover and the cap.
So, please has anyone had a similar problem? Can anyone answer the question about the filler cap seat?
Thanks!
Paul G
The other
Thanks!
Paul G
The other
