Thought I'd share my experience with the latest BMW battery charger - the black one which can handle Lead-Acid and Lithium batteries.
First one failed after two days - couldn't read charge state correctly nor measure any increase in charge so it kept pushing full amps charge into an already fully charged battery.
Second one works fine except...
I have a direct connection to the battery plus the Canbus plug up front (the bike is a 1250 GSA). The direct connection works fine but I've found that the Canbus is not always "woken up" whatever the handbook says.
The charger goes into an energy saving mode when the battery is fully charged (screen off and an intermittent yellow light). It also does this if it can't detect a battery (Canbus in sleep mode). You can't tell which is which until you try to start the bike and realise the battery is flat.
As I said - just my experience but I thought worth sharing to see if this has happened to anyone else.
