I was asked by a pal how good did the Storm Products we sell work..?
so i did a little demo on my Rukka Armas and Cosmic pants..
<p align="center"><font face="Verdana"><br></font></p>
<p align="center"><b><font size="6" face="Verdana"> </font><font face="Arial" size="5">Storm Wash In Cleaner & Eco Proofer Waterproofer Outdoor Gear Twin Pack 300ml</font></b></p><p align="center"><span style="color: rgb(51, 51, 51); font-size: 13px; background-color: rgb(250, 250, 250);"><a href="http://s582.photobucket.com/user/derekbuster/media/31312_zpsllawidty.jpg.html" target="_blank"><font face="Verdana"><img src="http://i582.photobucket.com/albums/ss262/derekbuster/31312_zpsllawidty.jpg" border="0" alt=" photo 31312_zpsllawidty.jpg"></font></a></span></p><p align="center">
</p><div class="page" title="Page 3"><p class="MsoNormal" align="center" style="margin: 0cm 0cm 0pt; text-align: center; line-height: normal;"><font face="Verdana"><font size="3">
Before and After Photo's
Storm Textile Wash and Proofer Eco,
Here is a few shots of before and after Rukka Jacket and Pants.
Storm Wash & Proofer Fantastic results like new.
We also sell the base and mid layer cleaners to.
Before
after
Before
after
When & Why.
So you have just used your new garment and it rained, it’s amazing how the water just ran off the surface and it breathed as the manufacturer said it would. This happens because of the DWR (durable water repellent) treatment that was applied during the manufacture of all waterproof garments. Over time, things like dirt, oil and normal household detergents will have a detrimental effect to the DWR, causing the outside of the jacket to absorb water (wetting out) rather than run off.
Breathability, performance and comfort can be reduced by this “wetting out”, making the garment feel heavy, cold and wet to the touch. Storm’s cleaners remove dirt, oils and stains without harming the DWR, making your garment work like new again, unlike normal detergents, which can damage the DWR further.
Your garment will lose its DWR treatment over time due to general wear and tear; this can be seen on the garment by way of the wetting out occurring straight after a clean. Storm’s range of proofing products can restore the DWR to its original performance. Storm’s proofing range uses the same technology that is used by major garment manufacturers in the production of their garments so will bond perfectly to existing treatments to restore performance, breathability and comfort.
To Heat or not too Heat; we give you the choice to select a heat activated product (ECO+ proofer) or the air curing proofer. The Eco+ proofer offers increased levels of durability and performance and is seen to be the Ecological choice when it comes to DWR chemicals. However not all garments or users want to go through ironing or tumble drying their favorite outdoor garments, so the option is yours. When using Eco+ products it is best to line dry first until almost dry and then tumble. This tumble should be at least 20 minutes on a low setting. When using an iron, have a clean towel between the iron and the textile set to a medium temperature without any steam.
Along with garments the same can be said for footwear, as they can be cared for in much the same way, keep them clean and re-proof as required. Tents and equipment also benefit from some TLC. Keeping kit well maintained will maximise serviceable life, reduce drying time and reduce the risk of issues such as Mildew.
Protect your kit and your kit will protect you.
Always check the item’s care label for manufacturer advice and recommendations.
This works on any outdoor waterproof textile clothing.
Available NOW at delsdeals
http://stores.ebay.co.uk/Dels-Deals
call Big D if you need any further info
Tel 07736157500
email: derekcumbers@talktalk.net
Before
after
Before
after
When & Why.
Tel 07736157500
