So folks - what is the knack to make this work properly on a 100gs ?
I don't think anyone has ever found a cure.
I personally think the best rear brake is the engine.
Knock it down a gear, clutch out and a squeal from the back tells you its worked
I know a local guy selling a US spec 93 red model similar to the above with only 13K miles on it for $2,000, c/w alu panniers.
There is a catch though........see address.
But I assume the rear brake must work a little at MOT time or do you just have to find a sympathetic MOT tester ?
I'll second the above.
The rod operated rear brake on my 1988 80RT (Mono) was quite good. but the cable operated one on the 1989 100GS (Paralever) does very little in normal use.
In an emergency it will work - but that's when you have an "Ohhhh Shiiiiiit..." moment and stand on it, whilst bending the front brake lever
(North side of Loch Tay . . in the dark . . and a large deer suddenly appears from the waters edge in front of you. I got the back tyre to squeal, I was impressed - its never done that before ).
Bob.
not tried any of this yet but thought I would :
- clean lining and shoes with something alcohol based to remove any shiny coating
- rough up the shoes with a file or wet and dry
- adjust the brake arm position so its vertical when it starts to bite in an attempt to get the best leverage
Judge - what do you think are the 'grippiest brake shoes' ?
Mike
Hmm, crazy paving very 70's.
Mike
My R100GS paralever rear brake is superb !!
But it has only done 4K miles
