ducatiparts.110mb
I'm looking to mount my (aftermarket) tyre pressure readout on the handlabars and would like to make a mount using the existing bolt that goes in through the cast alloy bar riser and screws into the tubular handlebar. (2010 R1200RT)
(Was trying to attach a pic but cant - not sure why)
According to the RepRom, you 'should not dismantle the handlebar as it would result in damage' making the bar impossible to reassemble. I suspect this means do not dismantle the whole bar, and removing the bolt then putting in a longer one with my fitting on it would be ok, but does anyone know for sure?
Thanks, Mark
Thanks, Mark
