Another tip I was given was to ram the piston in (and out) using a large screwdriver as this would give more oomph (better leverage) than relying on the brake lever.
This could prove difficult at 60mph IMO.
Well still no success bleeding the front brake. I have tried each and every method a number of times and still get air bubbles at first and when they go, no pressure at the lever. I wondered if I might have bought from Motorworks the wrong repair seals (kit) for the master cylinder so checked the number underneath the master cylinder (13) and yes, these were in fact what I fitted. Jim Cray suggested tapping the s/s lines with the handle of a screwdriver - I did but it no difference. Motorworks suggested my K1100 caliper was the problem as it's now fitted on the nearside ahead of the fork leg and back to front - but it worked OK before. He also suggested I undid the caliper and raised it a bit - I did but the s/s hose and steel brake pipe goes thought the mudguard and being rigid, I couldn't move it much.
It's getting very frustrating and whilst I've been successfully bleeding brakes on cars and bikes for years, I've never had this problem before. I know I'll go back tomorrow and find more air in the system. I always clamp the lever overnight too but with no pressure, that's bound not to work, and it doesn't.
But when the old rubber hose is replaced with the s/s one, air will get in and I'd be back to square one. I also thought about changing the s/s - steel pipe combination for a one piece s/s hose all the way to the caliper. This would at least allow me to swivel the caliper around a bit to extract that last air bubble.
I just can't believe that with all the pumping and various methods I've tried, there's still air in there. Perhaps as Motorworks said, "Non-standard fitment of the K1100 4-pot caliper, non-standard problems".
But thanks for your suggestion.
. I wondered if I might have bought from Motorworks the wrong repair seals (kit) for the master cylinder so checked the number underneath the master cylinder (13) and yes, these were in fact what I fitted. . .
You could try the caliper with another master cylinder such as the rear one or one off another bike - that way you would know whether it was the caliper or MC that was the problem.
Viv
