tallchris99
You may have two or more issues, one the gearbox has a bit of slop that causes a rattle when the bike is cold and ticking over more slowly and two, the bike may need valves, rocker end float and throttle position sensor setting up properly. This will make the bike run much more smoothly and reduce the rattling in the gearbox.
If Steptoe says it's gearbox rattle you can wager the lives of your loved ones that it is gearbox rattle.
Try and attend a meeting of UKGSers who also have or had 1150's, they will soon put your mind at rest as to how bad it sounds. Of course they will probably try and wind you up, instilling fear of imminent mechanical doom first
Thanks for the heads up.
