Results 1 to 7 of 7
Thread: Air injection
  1. #1
    Join Date
    Nov 2007
    shoeburyness
    Posts
    2,212
    Air injection
    Removed the Air injection junk from the thruxton today cleans the area above the camcover....
    Attached Images Attached Images
    Everyone dies but not everyone really lives....
  2. #2
    Join Date
    Mar 2015
    Surrey & London
    Posts
    1,882
    As per Del Boys garage instructions, i left the little plastic bit on, that connects to the wiring loom so as not to get a code. Since then i've bought a stage 1 kit from Triumph Twin Power which comes with software to sort that out (not fitted yet). Will you be sorting out the fault code or inserting a resistor? Mine was so much better to ride after taking this off. The backfiring before was ridiculous!!
    R1200GSA
    Triumph Scrambler 900
    Kawasaki Drifter
  3. #3
    Join Date
    Jun 2015
    woodhall spa, lincs
    Posts
    126
    +1 for the triumph twin power re-map, I sent my box off to him to install the tune and it came back with no fault codes for the removed air injection stuff.
    also did the airbox baffle removal, decent air filter and airbox inlet thing(breathe?).
    the difference is black and white.
  4. #4
    Join Date
    Nov 2007
    shoeburyness
    Posts
    2,212
    Iv removed the pump il put a diode to stop the fault code, brother in law has had the remap done, and for sure il do this with the airbox mod over the next few winter months, tins are off to paint so got some work to do before spring lol...
  5. #5
    Pestie to the Nobility Click here to find out how to Subscribe
    Join Date
    May 2004
    Worcestershire, England
    Posts
    1,658
    Hi, what did you use to bung the holes in the cylinder head after removing the AI tubes?
    www.severnvalleymole.co.uk
    Monogamy leaves a lot to be desired !!
  6. #6
    Join Date
    Nov 2005
    Newbury, Berkshire
    Posts
    12,151
    Quote Originally Posted by dicktheleg View Post
    Just screw a relevant sized bolt in it
    2016 BMW R1200 GS Triple Black
    2017 CCM GP450
    1980 Kawasaki Z1300
    2003 Sherco 250
    2002 Triumph Bonneville (Desert Sled)
    2017 Triumph Bonneville Bobber
    2003 Triumph Daytona 955i (Rob North Replica)
    1979 Yamaha XT500
  7. #7
    Join Date
    Jun 2015
    woodhall spa, lincs
    Posts
    126
    I got a kit online, couple of bolts and a couple of copper washers, think it was from square deals.
    The bolts were anodised black, but the anodising doesn't seem to like the heat, so they're a sort of faded black/brown colour.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
