Yep, I made a simple bracket and moved the klikronic body a bit further forward than yours. I found the SW Motech adjustable gear lever ideal as I could run a bolt through the bottom joint f the kliktronic shaft and secure it on the slot of the gear lever. this allowed a lot of adjustment. 2000 miles to France and back gave it a good test. My only annoyance is the shift buttons are currently bolted on to the handlebar grip, it fitted between it and the switch gear on her 700 but the twirly wheel gets in the way on this one.
