I am interested in having one of these retro-fitted to my soon to arrive GSA but reading through some of the posts there seem to be differing views of what this kit can and can't do. I found this excerpt below which I found useful and hopefully someone else might too.
The Pro Shift Assist was first available as a factory option on the 2014 R1200RT and R1200GS's built after August, 2013 (starting VIN: Z184816). If your bike didn't come with it, you can now retrofit this system.
(NOTE: It will not fit the 2013 R1200GSW.)
Features:
•Permits upshifts and downshifts without using clutch or closing the throttle.
IMPORTANT!
This system must be installed and enabled exclusively by an authorized BMW Motorrad dealer.
Also Required:
Enable code, sold separately, not available online. (BMW part number 13 61 8 545 879)
Details:
A first in production motorcycles, Gear Shift Assistant Pro provides shifts that are both convenient and dynamic. While originally developed for competition, the Gear Shift Assistant Pro now features greater functionality to adapt it to touring use. In virtually all engine speed ranges and under almost any load, it allows upshifts and downshifts without any need for the rider to operate the clutch or change throttle position.
Advantages:
•70-80% of all shifts based on riding condition can be executed without using the clutch.
•Gear changes are still performed as normal by the foot lever. The Gear Shift Assistant Pro only assists the actual gear change operation. The rider remains responsible for actually shifting the gears. This is not an automatic or semi-automatic transmission.
Notes:
•No assist for gearshifts is provided under the following conditions:◦ Shifting with the clutch disengaged
◦Upshifts with the throttle closed (coasting) or when decelerating
◦The shift lever is not in its neutral position before starting a shift
◦The system supports downshifts with an open throttle, but the shift quality is influenced by sudden or jerky throttle-on and throttle-off changes in lower gears
◦Shifts performed without disengaging the clutch in low gears at high engine RPM’s may be accompanied by substantial torque reaction during power transitions. BMW Motorrad recommends that the clutch is used to perform shifts under these operating conditions. Riders should avoid using the Gear Shift Assistant Pro at engine RPM’s approaching the engine’s rev limit.
•To ensure safety, cruise control is automatically deactivated during gear changes with the Gear Shift Assistant Pro.
Features:
IMPORTANT!
Also Required:
Details:
Advantages:
Notes:
