(2004 1150gsa twin spark)
Just wanted to check with the assembled masses the following:
I was just about to get onto the ferry last week when the bike started to surge a bit riding through the car park. However give it some more juice and it cleared itself. The servo unit then failed the next morning (rear brake control circuit) shortly the followed by the front wheel speedometer sender... Yes it was quite a morning.
Whilst I appreciate that the speedo is nothing to do with the servo brakes, I've noticed that the bike seems a tad laboured on the trip through France and had difficulty sometimes idling when either warm or cold in that it would start, run steady at about 1k rpm before trailing off to about 600rpm over about 30 secs and then splutter and die. However it would always restart and so long as I gave it some beans in second to get it through the laboured patch it would run ok but felt a little laboured. I also started to notice the whiff of petrol when stationary sometimes.
To me this sounds like the stick coil (s) is/are beginning to break down and as such I did the 'Steptoe' test of pulling the secondary caps and whilst it still ran, the rev dropped slightly and it began to sound more rough especially when diosconnecting the right hand side. Whilst I have not had the plugs out yet to check for colour (new last year during the service), I checked the TPS voltage a couple of weeks before and it was about 0.369v and all was running fine, I've also lightly sprayed some brake cleaner around the TB'd to check for leaks and there isn't anything obvious. I also need to check the air filter but it was replaced last year and was fine a couple of months ago.
Soooooo my question is whether anyone else has experienced similar symptoms after their servo failed but before completing a servo-ectomy (which is happening this evening when i get home from work). Logically I can't think why it would but if it means I don't have to buy a another stick coil, that would be a bonus. Incidentally I replaced both of them about 3 years (15k miles) ago - how long are they supposed to last??
Any thoughts much appreciated.
