After the spate of bevel bearing posts - had a couple of worried calls ( one turned out to be paralever bearings, waiting to hear from the other) - read on .
If you've got play in your rear wheel, it's not always the bevel output bearing, it could be play in the paralever pivot bearings, it can be difficult to tell between the two -
check which it is, by putting the rear brake on, and then feeling for play with the brake applied - if it still moves, it's the paralever bearings - if no play, it'll be the bevel bearing.
The paralever bearings can be adjusted, if caught early enough, but if they've had play for along time, chances are the bearings are U/S - use marine grease if just lubing them or renewing.
* The bevel bearing can be U/S without giving any play, so don't think just because it's noisey or graunchy, but there's no play, that it's OK *
