1050 speed triple gearbox issue
fizzer
co durham,england
a bit of advice really,one of my buddies has a 1050 speed triple ,its six years old but only has 8000 miles on it ,when easing of the gas it slips into a false neutral between third and fourth .
i have read about something called a detent spring behind the clutch basket anyone done one ,is it much of a job .
surely with that kind of miles it cant be a fooked gearbox can it .:nenau
i have fixed it,just in case anyone else comes across this ,the detent arm has a tiny bearing fixed to the arm the bearing had come off,its the size of your little finger nail, and was lying in the oil under the clutch basket ,you cant fix it ,it needs a replacement ,easy enough job one you get the clutch basket off :thumb
