Adam Gipp
Hi all
i recently bought some sst bleed nipples for my 1100 from motor works as i wanted to re new the fluid i thought this a good time to fit them.
the side that had the original bleed nipple is fine but the side that had the factory blank in is now weeping from the thread of the new bleed nipple (not from the centre hole i am sure). i have now put the factory blank back in and it seems fine so the threads are still ok .
i wonder has any one else experienced this problem in the past and how can you bleed the caliper with the factory blank in.
Any help would be graet please
many thanks Adam
many thanks Adam
