1100 rear drive clonk ?
Noddy
Some sort of clique thing
Thetford, Norfolk, England
94 with 34K.
Bike on main stand and not in gear, grab rear wheel with hands at 6-12, no movement, hands at 9-3 and again no movement wheel spins without any noise apart from pads on the disc but seems just fine. But if I rock the wheel in a forward and reverse direction I have about 1/2 inch of free movement and a clonk as the free play is taken up in either direction. Any other 1100 owner got this or do I have a problem?
My initial thoughts are UJ starting to wear but would hate to strip and find that they all do that sir.
Just came back from doing a lot of off road in the Alps but havn't noticed anything wrong on the road although its a bit hard to tell with the noise and vibration I get at slow speeds with the TKC's.
Any thoughts welcome thanks
Just checked mine (1999 R1100GS with 82,000km)
Moving the wheel forward and reverse gently in neutral [about 1/2 inch] results in a quiet tap from the drive shaft. I guess this is just the slack being taken up. Definitely no clonk sound no matter what I do.
If I engage a gear then I get a bit of a clonk as the gear is reached when turning the wheel.
Hope this helps
Gecko
Thanks Gecko, I tried a mates 1150 today but could't find any free play at all, maybe the back end is somehow different ?
Nah....I reckon he just hasn't ridden it enough ;) either that or he forgot to take out the retainer pin when he took it out the box :D
And the results at this time are,
Great Britain with........... 1 clonk
Estonia with....................1 clonk
Belguim with....................Null clonk
The score board will be updated later.
:D :) :D :)
I haven`t checked my two yet,but I will tomorrow and let you know....
However,it does make me think it`s either wear in a UJ (remember there`s 2 in a Paralever isn`t there ? ) or if the shaft has a shock absorber like the Mono Airheads,it`s that.
Unless of course,there`s wear on your bevel gear or crown wheel... :eek: :eek: :eek:
I mean i have the slight clonk turning wheel forward and back, but nothing on perpendicular direction. I guess that clonk it's some gearbox or shaft stuff.
No clonk (but play at 12-6 and 3-9)
'97 1100 - 42k miles
No play in either bike at 6/12 or 9/3,but one of them did have a new bevel bearing last year.
Can feel and just hear a slight 'clonk' in neutral when turning wheel forwards and backwards on the 47000 mile one.
Hardly at all on the 23000 mile one.
In first,doing the same,there is about 5-10mm wheel movement before the 'clonk' on the 47000 miler.
Just about 5mm on the 23000 miler.
It just appears to be backlash in the crown and bevel gears.
I don`t notice anything when gearchanging or accelerating/decelerating.
If it worries you,find an Airhead with decent mileage,and check it on that !!!
