I've suffered from a really stiff clutch for a while now. I've replaced the cable which helped a bit and also regreased the needle bearing on the actuation arm.
I've taken the swingarm off as my neutral switch is also playing up so I've decided to revisit the clutch issues.
There are two penny washers either side of the clutch actuation arm and they appear to be domed slightly. Should they be domed or should they be flat? It looks like these washers are taking the load on the lever itself and not the bearing.
Tom
Tom
