pax maac
95 1100GS
I followed Steptoe's writeup on the cylinder head gasket change, and everything seemed fined. Taking it off was easy, rotated to TDC, removed the head.
Putting it back everything seemed fine, I took extra care to make sure that the cam sprocket tab lined up with the index slot. I got it all back together and torqued up and was ready to adjust the valves. I rotated the engine after installing the head to make sure it moved freely, and it did. All the way around to TDC again, which meant that since it was at TDC to remove the left side, I had then switched it so that it was at TDC for the right side. I adjusted the valves there and everything seemed fine.
So now I had to rotate again to adjust the left side. Well the engine went as far as being able to see the letter Z in the little window and then it will not move any more.
I thought I better check the cam sprocket, so I pulled the left head again and double checked my work. It all seemed correct. The tab was in the slot. I reinstalled the head and the engine rotated freely all the way around to the OT in the window again and then it won't go any more.
I got frustrated and walked away. This morning, I just went and checked and what I have is this-
The right side valves are wiggly, as if ready to be adjusted. But instead of the left side valves not being wiggly, the left side intake valves are wiggly as well, but not the outflow.
Any ideas on how to remedy this situation?
