Hi all,
My lovely 1100GS is getting a bit 'knocky' from the right hand side. If I put pressure on the throttle body where the cable wheel is able to rotate on the body it removes the noise. I therefore think the bearing is shot in the throttle body housing ( if there is one?) Is replacing the throttle body easy or does it involve lots of hi-tech adjustments to be made when the new (or in my case read as 'used') part is fitted?
All advice would be really well received
Cheers all (especially Steptoe if you're out there)
Chod
Chod
