Ed209
Hi guys, searched the many many servo/abs problem posts but nothing helps. The bike is a 2003 gs adv with servos and abs. When I switch ignition on both lights flash as normal for a few seconds then the bottom one goes out leaving the top one flashing slow. I ride off and the top one goes out too. All ok. As soon as I use the brakes (either one) the top one flashes faster and the bottom one comes on and stays lit with the brake on, Soon as i let go it goes back to the top one flashing slowly. This is the same with just the ignition on. When i apply the front brake the servos whine as normal. When I apply the back break there is no whine but same flashing lights.
New oddysey battery recently and starts perfectly. When riding the bike the front brakes work fine and have normal breaking. I dont normally use the back brake and just tried it but no whine and it seems residual braking at best. I read about a microswitch on the back brake but mine seems to just have the plunger into the cylinder and no switches.
I did a short video of the warning lights but have no idea how to post on here
Any help apprieciated
Steve
Steve
so I'll start another thread!!
