I’ve had a man issue with my GS not starting and knew that the battery was ready for changing, so ordered a replacement one that’s turned out fine. I’ve also replaced the starter pack n the last few weeks as it was easier than refurbing the ‘lazy’ one I had fitted. That also turned out fine and the bike turns over as expected. However, the fuel pump wasn’t priming. Now have a new Kemso pump fitted but it’s still not priming (or firing up).
Things I’ve tested:
- Fuse 6 is good and the relay, swapped for the horn one, shows the relay’s working fine
- voltage across the fuse shows 12.5v initially, falling back to zero as the relay clicks
- voltage at the connector below the tank shows the same as above across green/brown pins
- continuity checked from the plug beneath the tank to the back of the plate and to the fuel pump connectors shows all good and no short between them, until I connect the pump, then there’s continuity between green/brown wires through the motor
- Fuel pump connected directly to a spare 12v battery spins up perfectly and sounds sweet
- plugged together, suddenly there’s no initial12.5v at the pump when the ignition key is turned and the pump doesn’t prime. Yet, if I check continuity through the connectors, it checks out fine from the back of the socket on the loom side, all the way to the fuel pump connectors in the tank. Without the pump I get the initial 12.5v but with the pump connected, nothing…
Anybody got ideas please as I’m running out of them..? Thanks
Things I’ve tested:
