1150 GS ADV GPS Bracket
Slime Bomb
Stoke on Trent
I want to use my car satnav on the bike and wondered if anyone has made a bracket so it can sit high up behind the screenlike the 1200 has in the pic? I have a satnav case that goes onto the handle bars but it's a little low. The only place to mount from as I can see is from the indicator threads. Any ideas?
Thanks for those but I was trying to find a cheaper option as cash flow is not so good at the moment.
I use a Migsel mount, but you can also get a bar from Rugged Roads that you can use if you have tobinators fitted.
http://www.ruggedroads.co.uk/shop/article_2050/Accessory-Mount-Bar.html?shop_param=cid=49&aid=2050&
Hth
Cheers for the plug :thumb
Here's a couple of pics of one we put on Fanum's GS - along with his existing Migsel mount..........a man can never have anough RAM Balls :D:D
Accessory Mount Bar
If you;ve got to buy it and its for a motorbike nothing it seems comes cheap. To go cheap you need to think outside the norm. If your lucky you will have a lathe and can make something. Most of us don't so its down to finding something that maybe has been made for another purpose. Something made with cable ties tends to be cheap.
Alternatively this is the cheapest bought option I have seen.
http://www.google.co.uk/products/ca...=X&ei=saYYT_iUDMen8gP5qrWiCw&ved=0CIABEPMCMAI
If you do come up with something novel please post it on here.
I for one can get a nice 5 inch Satnav for £50 that is far superior to the Zumo and Rider but its not waterproof and doesn't have bluetooth sound. The lack of which are major drawbacks on a bike.
A Tosser mounted :D
Its first time I've seen the finished result and reckon Fanny does have more balls than most :rolleyes:
Thanks for that B4ndit. That's the case I have and it's just the job for my nuvi 255w. Will let you know if I come up with anything. Thanks guys. :beerjug:
