Mr Otford
Since replacing the cat with a Y piece I've noticed that there is a greater tendency for the bike to backfire. Any thoughts?
TIA
Richard
TIA
Richard
It is difficult to do it on demand, I get best results from slightly off throttle after spirited riding.1 - Air leak somewhere.
2 - They all do that, the hard bit is doing it on demand![]()
I got exactly the same a few weeks ago when I replaced the cat with a Y piece. Did the Steptoe mod on the CCP and cured it instantly.
Did you seal the joints? If not put a bead of silicone round the inner pipe before sliding them together and clamping up. Ordinary clear bathroom stuff will do the job![]()
Dont do it !
Silicone will poisen your Lambda sensor and its non reversable !
remember the 'minute traces of silcone' in supermarket petrol recently that caused cars to break down !
google silicone and lambda sensors
Keep bathroom sealers for sealing bathrooms , not exhausts
Even the top grade automotive RTV's are only good for 225-250 short duration
Wasn't the idea that the silicone is between the inner and outer pipes? In which case if it gets to 250 degrees C, what it's doing to something upstream is probably the last of your worries![]()
The lambda sensor is down stream of where the 'Y' fits to the front 'pipes' and sits in the single tube of the 'Y' before going to the silencer
take a look at this web link to a Lambda manufacturer http://www.picotech.com/auto/lambda_sensor.html
a quote from the text ;
If somebody used the wrong kind of silicon sealer to seal up a leaky rocker box cover or manifold gasket, silicone can find its way into the engine and foul the sensor.
If you can apply RTV either to the male or female section of the pipes and then fit them into each other without pushing any silicone forward into the open pipe which could either migrate by burning, or vibration onto the sensor
then i guess you have nothing to worry about
It was the previous post that mentioned this, not mine![]()
I was talking about the sealant between the inner and outer parts of the pipe.![]()
Good link btwput it on the "my bike's using 25% more fuel" thread
