Finbarr
I've just had my 2003 1150 GS recalled to have the Lambda sensor wire which runs close to the right high tension lead be relocated.
Apprently there are reports that the HT lead interferes with the signal from the lambda sensor causing mis-fires and a generally rougher running engine (on some bikes).
Just so you know...
Cheers,
Finbarr.
Just so you know...
Cheers,
Finbarr.
