2sledge
can the timing go out of sink etc
the o/s cylinder is not firing // intermitantly
i have spark
injector is attomizing the fuel
throtel cabel is sat ok
wires to injector are ok the fuel is attomizing
i have swoped the plugs over
i have swopped the injectors over
swopped plug leads
compression is the same on each side i/e 128lb
the problem seemed to start when i put the battery on charge
checked all wires etc cant find a fault
tryed all the idears from the previous thread
any more idears
thanks sledge
it will start from coold run for about 30 seconds then die then it may start and will run rough and cut out
i have spark
swopped plug leads
any more idears
thanks sledge
