stuyvpc
Hi all,
I've got a 2002 1150 GS Adventure that I have had from new, its got 50000 on it and unfortunately the clutch slave cylinder blew this morning.
The new cylinder should be with me tomorrow so I've set to, with a lot of useful advice from these forums.
One problem I'm having is getting the rear shock removed from the lower mounting. The allen bolt is really tight, lots of WD40 and 'in/out' movement doesn't seem to have helped much. I'm concerned the b*****d thing won't go back in again when removed. The bike has done 25000 miles in the last 9 months including through the winter so I'm a bit concerned about corrosion in there. Or is this normal? Advice/suggestions appreciated.
Thanks, Paul
Thanks, Paul
. It all went back together Ok though. If the adventure is the same as a standard GS, you'll have to raise the rear frame a bit in order to get your hand in enough to get to the cylinder banjo bolt. I cut a wee bit off the end of an old allen key, which helped a lot.
