1150 hand guards on an 1100?
gog
Kirkcaldy, Fife, Scotland
simple question (I hope)... will standard 1150gs hand guards fit the 1100gs with no fettling?
I also have a JAW throttle lock installed, as he advertised these as fitting either model, I'm hopeful this will also be ok.
Yeah had thought of fitting them to my 1100 ..to get rid of the boxing glove look of the originals...😜..lol the Po of mine has fitted one of those throttle locks tho I'm thinking there must be a washer missing as I cant adjust it ...???
what type of lock is it WCG? mines a jaw engineering one. sometimes it get jammed off *really* tight. thankfully it doesn't jam on!
same as mine. it gets really tight as the friction from normal throttle use tightens it a little each time. if ive not used it in a while it takes a hell of a twist to free it off. one of the washers in mine flaps about when its engaged too, which im not sure its supposed to!
