1150 Oil leak
Zebedee
Dorkland, NZ
Right folks, my bike is leaking oil from the area where the cam chain goes into the head on the RH side.
The history is that I spat the bike down the road a while back, and it ended up sliding down the road on the RH side.
So, to the question: What's the best way of fixing the leak?
Is it worth re-torquing the head bolts and hoping for the best, or have I got a bigger job on my hands?
On the other hand, should I just pretend that it's an old Brit bike and keep topping the oil up, because the performance doesn't seem to be affected :D
Cheers :beerjug:
John
Gasket change. Steptoe did a sticky write-up in this technical forum at the top. Also seems to be missing a bolt where the leak is right hand side.
Thats where the plastic protector bolts into on a single spark. That bike is a twin spark ( see the lower plug cap) and they mount in a different place, so that hole is unused .
Try torquing the head down and see what happens.
Cheers Neil,
Like Snoopy said, I did wonder if the spare hole had anything to do with the problem, but I checked on the other side and found a matching hole, but no oil leak. So thanks for clarifying why I've got a couple of spare bolt holes, too. :D
I'll try re-torquing the head bolts, and we'll see how she fares :thumb:
Thanks for the assistance guys, have a good New Year
John
