1150gs Rear Shock replacement
Spud
Fylde England
About to replace the rear shock on my 113,000 mile Gs as it's still the original.
Is there anything special you need to know before tackling the job. Or is there a "How to" video anywhere.
Thanks in advance
Spud
Rear wheel off, straight forward, you might need a blow lamp to warm the loctite on the bolts, they are a nuisance to remove the first time
Plenty on YouTube, just type it in and follow. There's one really good one in Spanish but you do not need to spk that language to understand and follow it.
Sent from my VOG-L09 using Tapatalk
Plenty of heat from a hot air gun and take it easy with the lower bolt work it back and forth a bit or there is a risk of stripping the threads out , much simpler than an LC rear shock swap
